The ECU thinks the remote oil tank needs oil feed to it. I ohmed out the float and it tests good. no bars flashing on my gauge. even though the remote tank is full it keeps feeding oil to it and its overflowing.
2001 200 hpdi, ECU "thinks" remote oil tank needs filling, alarm sounding with KOEO
And... just to be clear, you're talking about the MAIN oil tank, right? The one on the engine is the main tank... the big one is the boat is the remote.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Thanks for clarifying, I had it backwards, its pumping oil to the main tank and over filling it. Still learning for sure.Originally posted by DennisG01 View PostAnd... just to be clear, you're talking about the MAIN oil tank, right? The one on the engine is the main tank... the big one is the boat is the remote.
And I apologize, I did not do a very good job making my first post more into a question. I am hoping that someone has run across the same circumstance.
Note... there are guys on here with much more knowledge than me, but these are things I would check until someone gives better advice...
With the float out of the main tank, but still connected to wires, the float should drop down and simulate a low tank. Do you then get an indicator of low oil on your gauge display? I'm wondering if there's a disconnect in the wires from the float to the ECM.
If the dash gauge reads properly by you manually moving the float... could the pump somehow be stuck in an ON position?2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
