Stator and rectifier both pass ohm and diode tests. Both look brand new. What else could stop charging? Can’t find wiring diagram for vmax.
2002 150 V Max not charging
V150TLRA is the model. Tells us that it has carburetors. Not that this matters in your case.
Was the lighting coil tested for output voltage? Ohms can be good but if the coil is shorted to ground the output will be down or non existent.
Yam has the lighting coil tested for peak voltage using a peak reading meter but your regular mutli-meter set to test for AC voltage will give you a good general idea.
Three green wires. A, B and C. A to B. A to C. and B to C.
Wiring diagram is in the service manual.
