Hi All,
Is there a 02 sensor in the Yam 60hp made in 2008?
I am having a "running rich" problem with all the associated symtoms; bad mpg (300ml/km) on a 500kg RIB, black engine oil after only a few hours, sooty propeller hub exhaust, sooty plugs.
I tried a 10k ohm pot on the tps and the manifold sensor and was able to manipulate the output voltages but without a airfuel mixture gauge not easy.
Is there a place on the engine that I can install a o2 sensor??
Cheers,
Christian
Cheers,
Christian
