Looking for some help with an issue we are having with our 2005 Yamaha F225TURD. We recently pulled the outboard apart to install an exhaust corrosion kit, new water tube, new oil pump/crankshaft speedi sleeve, new water impeller and new fuel injectors. We got it all put back together and went to test run it and it fired up right away but we are not getting water to come out the tell tale. Its being run in a water tank and not with muffs. When the motor is run water comes out a hole near the lower bracket screws and water comes out the oil drain plug area. I uploaded a video on YouTube today that shows the problem as its hard to describe. Is there anything that could be causing this that I am overlooking? We pulled the lower unit again today to make sure the water tube was lined up correctly and it was. Blew some compressed air thru the tell tale to check for clogs. It is about 0 degrees here too so not sure if maybe some water froze in one of the lines but that seems unlikely since this is the first time it has been started in over a month. All cable/hoses are reconnected except for the intake silencer is still off. Any help you can provide is appreciated!
https://www.youtube.com/watch?v=xF8L...ature=youtu.be
