Hi guys!! When installing new impeller and putting housing on WHAT direction an I turning the drive shaft ???? Im thinking clockwise since my mercruiser housing eases on that way but this is my 1st Yamaha 2000 200HP Saltwater series 2 stroke.Thanks
Impeller housing install vane direction??
thanks guys.I usually use a light coat of marine grease in the housing .BTW I also heat the impeller slightly to soften the rubber impeller so it eases into the housing.I learned this only because I tried doing an impeller change in a cold garage in Feb and it wouldnt go on from being too stiff from the cold so now I heat it a little.Actually warm it
ÂÂÂÂ
