what exactly does it do and mean if when unplugged I have no issue starting my motor? With it plugged in it has no spark. 1991 225 carbed txrp
Yellow cdi bypass wire
Originally posted by 99yam40 View PostI do not really know, but I think it bypasses some of the controls to spark incase something fails so you can get back to land
someone will have to test everything to see what is missing
voltages into and out of the CDI should help point in a direction
Connecting the yellow wire puts the motor into the fixed ignition timing mode. Used in the event there is a CDI malfunction that prevents the motor from starting, the RPM from being stable, or the motor fails to reach an operating RPM.
Yeah. I understand that part. Im just curious,if I had a bad stator or pulsar I'd assume the yellow wire would have no effect in anything?
Have you tested the coils and other components for proper output voltage?
The yellow wire needing to be disconnected indicates there is a problem. Which was probably already known. The problem that is. It is up to someone to trouble shoot the system to find the source of the problem.
I'm trying to trouble shoot it. I have limited info. I've been an automotive mechanic for the past 25 years. I am capable of figuring things out given the proper resources. Also, im not familiar with 2 strokes so I'm learning as I go.
I too was a auto tech way back in the day, before I turned into a industrial electrician and then and I & E tech
so you will have the proper info to read in a Yamaha service manual for your motor,
or look on the web for CDI Electronics Troubleshooting on Yamaha for the specs
I have the yamaha manual. It's lacking info. I just googled the cdi info and will check voltage tomorrow. only problem is my engine isn't listed except for the appendix
LIT-18616-00-61???
Send me your email via PM and I will send you data indicating the voltages. The attachments here are no longer working well for me.
ÂÂÂÂÂÂÂÂÂÂÂÂ
