Try bypassing separator and go rite to the filter before the LP pump with a different clean tank. This will eliminate that whole list.
primer bulb goes flat at higher RPM
If conditions permit, run with the cap looser for a longer period of time. Or, just disconnect the fuel line at the canister (the one that comes from the tank). This is just basic plumbing to bypass the canister - you have a fuel line coming from the tank, the mumbo jumbo of the canister stuff, then a fuel line going to the hull vent. Just connect the the two fuel lines together and make sure there is no dip in the line anywhere. The line should progressively go up and, ideally, end with an upward loop at the hull vent.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Just a thought, could the culprit be the fuel bulb itself?
could it have junk in it and/or the valve in it sticking shut? By pass it.
Originally posted by JimBen14 View PostAfter I fill the tank with fuel and get to 3500 rpm, my yamaha 300 loses power. It may actually sputter to a stop and take a few minutes to start. I have checked the primer bulb and it is flat. Any advice as to what would cause this?If it strokes more than twice, you're playng with it
Bulb has been replaced and still happened. Considering following Dennis's recommendation and by passing the canister. I looked on Youtube, but couldn't find anything.
Originally posted by JimBen14 View PostBulb has been replaced and still happened. Considering following Dennis's recommendation and by passing the canister. I looked on Youtube, but couldn't find anything.
However, can you get to the vent fitting on your tank? Get a length of 5/8" hose and remove the vent hose. Put the new hose on the vent nipple and secure the new hose - tie it off to something - just make sure there are no dips in the hose. This is now your new vent hose. The will 100% determine if the event system on the boat is the culprit. You "could" run with the vent hose just removed, but you run the risk of fuel spilling out or water splashing in. Just to cover all your bases, blow into the new vent hose to make sure the vent fitting, itself, isn't clogged (although that is extremely unlikely).2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
A proper vent hose will have a loop up high as possible next to the vent to the outside of boat. And always ck vent for bugs and nests
ÂÂÂÂÂÂÂÂÂ
