Strength of some magnets today are dangerous.
Wanting to add a battery charging circuit to manual "pull start" F25LMHC
Originally posted by Tony Harper View PostThat reg/rect supplied on the manual/pull start engine from factory only runs the fuel injection system, you will need to buy/install a new rect from Yamaha, it is a different part number but looks the same visually, you will need to look up the part number for the reg/rect on the same year model F25 but it has to be a factory electric start model, that reg/rect is the one you need to run battery charging on the manual/pull start version.
I have a 2018 F25GMH outboard and I'm also trying to charge a battery from it. I have fitted a new and original wire lead (6FM-81949-00) between engine and battery but it is not charging the engine. Will I just need to replace my rectifier/regulator with 6FM-81960-10-00 or will I also need to replace the stator?
Thanks in advance for your help.
Originally posted by Chad D 1974 View PostHello, I have a wood boat I just finished up and installed a new 2020 F25 manual "pull" start engine. I would like to add a battery and some electronics like a fish finder and nav lights. The owners manual says it has a 16amp alternator. I've located the rectifier/regulator but am unsure where to wire the battery leads and fuse block. It seems this should be straight forward but I can't find any info on the matter. Is there an installation kit required? There doesn't appear anywhere connect 12ga wiring.
Have you managed to work out what parts you need to charge a battery from your engine yet? If so, could you let me know and any part number(s) as I’m trying to do the same.
Thanks,
Pieter.
Originally posted by jasonwah00 View PostI am trying to do the same. I have a 2019 Yamaha F25 SMHC, which is the manual start. I would like to be able to charge my battery from the engine.
I do not want to add the electric start kit though. What parts would I need to order?
Would it just be?
6FM-81960-10-00 (Rectifier and Regulator ASSY)
Also has anyone tried this and how well does it charge the battery?
I have a 35AH battery, and my electronics draws about max 3 amps, and I plan to be on the water a max of 8 hours.
Thanks!
Thanks,
Pieter.
Originally posted by FlyingDutchman View Post
Hi Tony,
If you provide the complete engine ID someone here might be able to help you.
ÂÂ
