I have a yamaha temp gauge. I would like to hook it up to my '92 85hp yamaha. It has 3 wires off the back along with the 2 lighting wires, light blue, yellow, and black. Where does the light blue wire connect to? The ole guy at the counter at my yamaha dealer said it connects to the alarm buzzer sending unit on the head. Can someone help or send a schematic, I sure would appreciate it. Also, I have a digital speedo. The set and mode buttons do nothing and the 's' video type cable is not hooked to anything. I need some guidance on that also. Thanx
yamaha temp gauge
Dan,
I'm pretty sure that blue wire goes to the temp sender that you mount in the top of the cylinder assembly.
As far as the digital tach, on mine there are three little "dip" switches on the back (2000 model):
#1 - up for 2-lead trim sensor and down for 3-lead sensor
#2 - up for 6 pole altenator and down for 12
#3 - up for 4 stroke and down for 2 stroke
Your newer digital tach may be different - hope this helps [img]smile.gif[/img] ,
Ken K
If this a Yamaha Temp gauge then the Dark blue ,black,yellow connect to gauge harness connected to key switch. The light blue and other black connects to 688-83591-00-00(does not come with gauge) temp sender that connects to engine.
Dan,
When I installed the Teleflex temp gauge on my C115, I only had to use one wire from the sender on the motor to the gauge - the signal wire. In fact, I picked up an unused wire in the harness that was open both at the motor and under the console.
The second wire, black, just hooks the common ground of the cranking battery and the motor. You can pick it up under the console, unless that Yamaha gauge requires a "floating" signal return, in which case you will have to run two wires to the sender.
Hope this helps [img]smile.gif[/img] ,
Ken K
Â
