As noted above, I'm looking for an excellent quality (12 volt or 110 volt) oil pump for changing specifially oil from my engine.
I had purchased a hand pump set up, with (very high reviews and not cheap) however the comments were way over rated. It does work, if you don't mind constant pumping and taking easily an hour to pump 5.5 quarts of engine oil.
I currently have the steel container, the long thin tube to slip into the dip stick hole, etc.
Now, just a good electric pump that'll last more than a couple of changes without burning up..
Recommendations from personal experiance anyone?
(and yes, I did do several searches on-line)..
Thanks..
Thanks..
