I bought a 2016 yamaha 150 a few months ago. It had 40 hrs on it and since then I have put about 30 more on it and it has run great. Yesterday when I started it gas was leaking from a screw on the front part of the midsection near the bottom. It was leaking at a pretty good rate. I took off the cowling cover and inside was completely dry. After letting the motor cool I restarted it and after about 3 minutes the leak started again. Any ideas?
2016 Yamaha 150 gas leak
There's no fuel lines down that low. Your leak is coming from somewhere much higher than that.
Most of the fuel parts are on the starboard side of the engine, fuel pumps(if an F150) are on the rear.
Pull the top cover, put it on muffs and crank it up (if no fuel run off is visible) .
Keep a close eye for the leak, might keep a fire extinguisher close...
.Scott
