Originally posted by 99yam40
View Post
It did not have pitting or what I would call corrosion on the mount sealing surfaces bit it did have some kind of residue that I could not see when it was mounted. After taking it apart, I cleaned it with acetone and used some 1000 grit wet/dry to clean up anything that was left.
I put the
bulb between the filter and the outboard which was where it was originally. All arrows pointing in the right direction.
I only put the bulb before the filter once to test the bulb.
The bulb does indeed now get hard and pump fuel. Charging my *****ing batteries now for back up and will take the boat out in the morning if the weather is ok. Can't really test it under load in the barrel.
Thanks!
