Hello all! I hope everybody is doing well. I have a problem that hopefully someone can help me with. In 2014, I purchased a 1998 Yamaha C115 with a boat. The motor looked real clean. Before I attempted to run it for the season, I decided to service the components on an outboard that one expects to eventually fail; spark plugs, thermostats, gas / water separator, inline gas filters, new gas lines, new primer bulb and of course, the Water Pump. Upon removing the water pump housing and lower plate, I saw quite a bit of rust on the driveshaft bearing cap where the oil seals sit. I also noticed the lower Unit gear case housing dripping a bit of oil from the propellor shaft carrier bearing housing where the lower seals sit. I removed the oil plugs to discover the oil was milky white - an indication that there was water intrusion. I purchased upper and lower OEM seals (2 up top and two on the bottom) as well as the Yamaha service manual for that motor. I removed the old seals with the correct tool to not score the seat walls, cleaned everything up so no burrs were evident, found a truck socket that fit the outer circumference of the seals, and pressed the new seals in so they bottomed out. The upper seals with both open sides facing upward to the drive shaft splines which contacts the powerhead; and the lower seals with both facing outward toward propellor nut. I have a very small compressor with a regulator; rigged up my oil oil pump line and connector directly to my compressor and carefully regulated the air between 7 and 10 lbs to listen for leaks. It held pressure, so I buttoned it up and ran it. After my second trip, I decided to take a peak at the oil to verify it was in fact black and not mixed again with water. I had a little bit of clear water come out and again.... milky oil! I retraced my steps and could not determine why water was still intruding - especially after my (not so pro) pressure test. I suspected maybe a defective seal - or most probably user error, as I somehow slipped or ****ed a seal crooked. I decided to do all four seals once again. Finally, it's 2016 all tested out as I expected so I ran it.
*2017 - 2018 - replace entire water pump - no evidence of water in lower unit, changed oil, new crush washers
*2018 - 2019 - replaced impeller - no evidence of water in lower unit, changed oil, new crush washers
*2019 - 2020 - Ready to replace impeller, change lower unit oil and crush washers when.............
Last week, I proceeded to drop my lower unit oil to replace and a good pint of clear water drained hard from the casing! I was shocked! Upon benching the lower unit, I did my pressure test to hear both the upper and lower seals leaking; the Lower carrier bearing seals hissing consistently; the upper bearing seals were expelling air louder as I pressed sideways slightly on the drive shaft. I'm the first to admit I am not a professional mechanic by any stretch....... but this kind of maintenance procedure is something I presume I can do correctly as it seems not very difficult to achieve with the correct tools, literature and patience to do correctly.
Questions:
* With what I've explained above, does anyone see anything I may be doing wrong to have such poor success replacing these oil seals to have them work correctly as designed? If not, any suggestions?
* I mistakingly dropped the woodruff key in the exhaust area of the lower unit. Is this a concern with respect to it interacting with anything in the motor that can create another problem?
* Is it imperative I use "Hypoid Oil" as the service manual indicates - or is 90 weight Lower Unit "Yamalube" oil also suitable these days for Hypoid Gear applications?
Thanks for your time!!
Questions:
