Hi guys/gals.
I am nearly ready to throw in the towel on the issue we have with out boat motor. Any help is much appreciated as we've contacted plenty of mechanics and they've all said the process we've gone through is pretty much by the book...But still no joy!
The engine has done around 2200hours, has been rigorously maintained including 100/500/1000 hour services.
THE ISSUE
It started maybe 6 months ago when the motor has been started and in idle. It will just cut off. Restart it with no issues and run finw the whole rest of the day. This random issue has slowly started happeneing more and more often. But can still run for half a day without cutting out. Or be a pain and die within seconds of starting. This only happens at idle or just when putting into gear. Motor runs perfectly and has never cut put once when under power.
We can get it to cut out sporadically by lifting the motor with tilt up to around 45° or consistantly by using the tilt switch like a strobe light, rocking the motor quickly.
We are very lucky to have a second 130 (only difference is a long leg) with 200 hours that we've been using to swap parts from and this is what we've managed to change:
Tote tank direct to motor with new hose and no filter, eliminating boat side of fuel system
Remote contol from donar boat, direct plug into our motor eliminating boat control wiring
New battery cable
New battery
Changed inlet manifold with throttle body
Changed complete fuel section of line/mechanical pump and micro filter
Changed high pressure fuel pump
Changed crank sensor/cam sensor and knock sensor
New spark plugs
Disconnected tilt motor/sensor
Changed wiring loom and computer
Changed throttle control module (where the cables clip onto)
Only things left are some of the direct sensors bolted to the motor and the charging system
Maybe the main question I need answered is should I go with Honda or Suzuki?
Thanks for making it through my story!!!!!
Again, any help is hugely appreciated-
Cheers!!
THE ISSUE
New battery cable
New battery
New spark plugs
Cheers!!
