Looking for help installing a used lower unit I purchased on eBay.
This unit will not shift into F N R consistently. I installed the unit in Forward. After the drive shaft was inserted into the powerhead, and shift shaft lined up, I rotated the prop with my hands, slipped immediately into halfway neutral... clicks and then sometimes picks up Forward again when continuing to rotate prop. I disconnected the controls and shifted manually to ensure full stroke, symptoms did not change. I can get into reverse but Neutral and Forward seem to have issues. probably a clutch dog or gear wear I assume.
Any other tests I could do to make sure?
