Is the alarm for the above the same as the small horn button? trying to find my alarm to see if its working?
alarm on yamaha 50 tlr
Originally posted by 99yam40 View Postyou did not give much info on the motor or the boat it is attached to,
but the R says it is a remote con*****ed motor,
so the buzzer will be in the controls what ever they are
If a tiller model the warning horn will be in the tiller handle.
If an external side mount control box (key switch is part of the control box) the warning horn will be in the control box.
If a top mount control box the warning horn will be in the switch panel.
Pull the kill switch lanyard. Crank the motor. The horn will probably sound.zhorn.jpg
Originally posted by boscoe99 View PostIf a tiller model the warning horn will be in the tiller handle.
Pull the kill switch lanyard. Crank the motor. The horn will probably sound.zhorn.jpgLast edited by jlslavey; 01-11-2020, 01:22 PM.
ok i finally found my owners manual for the yamaha 704 remote control box. I have looked at all the info and I still cannot seem to locate where the actual audible button is located. Does anyone know where or have a picture of it they can share? I've went to a couple of sites to order parts but no one show a " low oil or high temp sensor". I do know that the horn button is not hooked up and am wondering if this is used for the sensor ( although I don't think it is due to it being on a rocker switch.
Originally posted by jlslavey View Postok i finally found my owners manual for the yamaha 704 remote control box. I have looked at all the info and I still cannot seem to locate where the actual audible button is located. Does anyone know where or have a picture of it they can share? I've went to a couple of sites to order parts but no one show a " low oil or high temp sensor". I do know that the horn button is not hooked up and am wondering if this is used for the sensor ( although I don't think it is due to it being on a rocker switch.
If not, what is a small horn button? For the boat horn?
By audible button are you talking about the warning horn? It is behind the key switch panel. Just like is shown in the illustration above. The illustration on the right.
ÂÂÂÂÂ
