Originally posted by 99yam40
View Post
View Post
The carbs were from a blown engine according to the ebay seller. I think he said it threw a rod.
I don't think you could find a better set of used carbs if you tried, although I only removed the bowl from the #4. I have little doubt that the others are just as nice. I know the effect of this engine running with bad carbs. That is what started my adventure in the first place
My plan of attack..
Look at the plugs and check for something I might have overlooked externally. I will also do the plug wire test.
I will recheck the valve adjustments. I picked up some new gages tonight. If I see something wrong with the valve adjustments, I will correct it and run the engine.
Just to verify if a screw is in the cylinder, for my piece of mind, I will loosen the carb assembly and peer into the throat to verify the screws are all there. I well also account for the other two screws from the other #4. Very doubtful though, The noise does not indicate that, It is coming from front, at the intake box. I would think if something was in the cylinder it would ping and be coming from the rear of the engine, where the cylinders are
I will let you know my results.
