Morning,
I have a V4 115BETO acquired recently I have worked through some major starting issues over the last few weeks and now after 5 attempts at launching and problem solving we had a successful run at the weekend.
The next day when trying to start on the slip way the starter motor nose cone sheared off completely after two attempts at starting, the engine fired and ran, then died as the bulb was soft.
On the second attempt the nose cone sheared off.
I have sourced a new starter motor but am concerned about a possible underlying problem that caused the starter motor to shear.
Is it likely there was too much pressure on the 25 year old starter motor as it received heavy use trying to start the engine these last few weeks when the carbs were dirty and fuel line blocked or whether it is an indication of another underlying problem?
The engine is not ceased and the flywheel moves freely.
Stop8
Stop8
