the manual says preliminary adjustment is to turn out the pilot screw 1-1/4 turn port side, and 3/4 turn out starboard. I use this method on the earmuffs and works perfectly. I also set the idle adjusting screw 1-1/8 turn out. When I put in water, it wants to die. I know how to adjust the pilot screws on a 3 cylinder outboard, but don't know where to start on the 6 cylinders, and the manual doesn't say anything about the final pilot screw adjustments. Where to start, adjust cylinder 1 and 3 together, then 2 and 4? I'm taking the boat to a Yamaha dealer for adjustments but I just like to know how they are adjusted? tks
idle speed adjustment
keep in mind that the idle will be 150 to 200 rpms higher when on the hose as there is no back pressure. Set your idle a little higher then water test it. You should be able to idle in gear at 500 - 550 rpms without stalling. However, the manual says it's higher (~700 rpms)than what I stated and that's fine as well.
Good luck!
