I need a 30" driveshaft for a 2003 Z150TLRB HDPI motor... but, none of the parts diagrams show one... so, I was wondering if any of the driveshafts from a different series would fit? Anyone have any experience with this?
Drive shaft question
description:
What that is is a 1" hole saw turned backwards and locked into place with a 1/2" jam nut. This acts as a pilot. And the 1 1/8" hole saw turned to cut/ream the hole to the size I wanted. It is all mounted on a fine thread drill rod. Hope this helps some one here with a similar problem some day.If its got teats or tires, you bound to have trouble with it....
If your motor is the X version then it would be a model Z150TXRB. Not a Z150TLRB.Originally posted by Mr. Nice Guy View PostMy current motor has a 25" (it's the XL version)... but, my boat needs a 30" (26" transom)... I bought one of those Bay Mfg extension kits - but, the drive shaft extender won't fit into the driveshaft hole in the mid-case. So, I was hoping to find a 30" shaft that I can fit instead.
A Z150 was never offered in a Z150TURB configuration. U being the designation for a 30" shaft.
You may have to remove the mid-section bushing in order to fit the existing drive shaft with the Bay Mfg. extension to install the lower unit.Last edited by boscoe99; 05-21-2019, 05:52 PM.
