I own two Yammies with two different issues.
1) 90 hp 1995 two stroke won't exceed 4500 rpm. It is new to me and has a 13 1/4 X 17 prop, does not seem to matter how it's loaded, heavy or light, just peaks at 4500. Would the 15" prop be an answer? It's on a 17' Scout center console.
2) 70 hp 1988 two stroke has small oil leak I can't find, the level in the reservoir drops a tiny bit and the oil runs down the lower unit leg, not bad but I'm curious as to where it could be coming from and is it repairable.
As a side note, referring to #1 issue above, the 70 is on a 13' Whaler and has the above 17" prop pitch and cranks up to 5600 easily.
Have to add, I'm on this site every day and enjoy it immensely!
