Yam, do you know what model and year of this engine? I may be interested in the carbs if you still have them.
Rodlbolt; Looking for parts motor
All I remember off hand was it is a single carb 2 cylinder motor.
But I can see if I can find any info on the parts.
might still have the id tags
Bosco my brother has a son that lives in Spring Tx.
he heads up there often, so I could get him to drop it off at his son's house.
that is about as close as I can get it to easily, and free
You or your brother planning a trip to see each other anytime soon?
Motor is a 30ELJ
689 L 416556
power head as it sits right now weighs about 45lbs
I can strip it down farther
head , exhaust cover,and intake.
not sure if you want the upper and lower crank housing on it
carb has 68973 6A on it
spring is 26 miles from Willis
the output was another one I was thinking about too.
not sure what that 30 from 86 puts out but my 1999 c40 only puts out 6 amps, so am fairly sure that 30 does not go above 6.
probably need to rethink what size and type motor parts you are wanting.
need to eliminate the pressed cranks or at least have rods that have caps so you can remove them easily.
then decide how many amps you want so you can target that sized motor
A 75, 80 or 90hp 3cyl yamaha 2-stroke puts out 10A and has con-rods with caps for easy removal. Don’t know if that’s what you are looking for but just fyi.Originally posted by boscoe99 View PostI was thinking of a three or four cylinder later (1990's) model something or other. Preferably a two stroke as the crank would be easier to rotate and keep lubed. I think. Ideally with about 10 amps output.
