Any O-rings in the oiling system look flattened loosing oil pressure?
Were you able to check spec's with a feeler gauge on the pump itself?
65.3 lbs at idle is spec for the F150 so 72 lbs is in the ball park.
NOW, besides the oil filters being on other sides, I did see the "OIL RELIEF VALVE" (page 1-13 yamaha F150 shop manual). See bottom picture.
Its located inbetween the oil filter bracket and the actual oil pump. Same page show oil flow from the oil pan TO strainer TO oil pump TO RELIEF VALVE TO oil filter bracket TO oil filter, etc. Cannot find it anywhere for the F115
Found it on the F350, in between the pump and filter bracket(part #16):
http://www.boats.net/parts/search/Ya...PAN/parts.html
__________________________________________________ ______________________________________
For the F150, part #34:
http://www.boats.net/parts/search/Ya...201/parts.html
