I have a 2004 F115
History- Bought boat as a theft recovery, lower units and hyd steering stolen
Checked compression to ensure good enough to warrant spending money- compression all approx. 180.
bought new lower units/props
PROBLEM- I have crappy useless gauges, buzzer going off intermittently, mechanic said key switches- replaced- NO CHANGE and he charged the crap out of me......
Got tired of it and started diagnosing myself- found out Oil pressure switch is turning on, activating alarm- Hoping bad OPS, put mechanical gauge on and oil pressure drops way low (to (15 psi) after running for a few minutes.. Book specs are approx. 49 psi at idle, OPS turns on below 24 psi
QUESTION #1- Is oil pump only thing that can cause this issue ( no main or rod bearing noises and compression is good). I plan on checking pick up strainer when remove power head.
Question # 2- I'm fairly mechanically inclined, any body have any tips for removing power head to get to pump
PS- This motor is on a 24 ft polar deep v, has twins, the other f115(starboard) oil pressure reads 72 psi at idle, 90ish psi at 2500 rpms (no issues with it).
PSS- I have already changed thermostats, cleaned poppet valves, installed new injectors, changed oil - ( all preventive maintance since was a theft recovery and prob abused)
THANKS GUYS!!!!!!!!
THANKS GUYS!!!!!!!!
