2001 Lower unit tilted down: A problem?
    You can not compress air!
      Dang, then what does my air compressor do?
        It is all air and know fluid.
        • #19
          could you get to the unit while tilted up to add fluid?
          have you ever heard of a motor that you have to lower the motor to add fluid?
          Tilted up was the only way to get to the crappy little plastic tank
          • #20
            well if this is true like I thought, why does he need to lower the motor before he adds fluid?
            does not make any sense to me
            • #21
              you are getting confused.
              you can compress air/gases, but cannot fluid
              how can someone or something know fluid
              • #22
                It is not the same, you can not compress air in
                to fluid. It is like trying to burn water out of gas in a carburetor.
                • #23
                  just playing with the words you wrote
                  gases will compress, and air into fluid does also.
                  just at different rates
                  if you compress and cool it enough it can become liquid
                  the air is still compressed, but does not move stuff like pumped fluid does
