My trim and tilt cylinder(s) on my port 2001, 200 HP HPDI are leaking a bit and will not lower the motor from the fully tilted up position requiring me to bleed it to the 'down' position every so often and then add fluid to allow it to work OK for another few trips. I follow the manual's process for bleeding /filling etc I will have the system rebuilt the season is over and the boat is on the hard , but for now I wonder about the wisdom of just leaving it in the down position after use and continually until the boat gets pulled in late October . I am in New England waters if that affects the thinking ion the subject ?
The lower unit seals were all replaced just 2 years ago and should be in great shape.
Waddya think....ok to leave it tilted all the way down in the water for an y extended time
Thanks for any thoughts or recommendations.
