Hello:
I have a 705 Flush control that is loose. It is separating from the fiberglass by about 2-3cm. I tried removing the handle and removing the black cover/ring, but it is not coming off. Does that ring need to be pried off with a bit of force, or should it be coming off by simply twisting? Correct me if I am wrong, but I should be able to tighten the screws once I get that cover/ring off, right?
Thanks for your help,
Roger
Roger
