Learning about outboards and how to work on these demonic things so please bear with me.
Issue started off as a cold start issue, once it started the first time, it would start back up no problem the rest of the day.
It devolved to no longer being able to get it to start at all. I have verified fuel flow past the mechanical fuel pump on the starboard side of the engine (installed a new primer bulb, new filter element and new pump).
Verified that I have spark (yellow in color in the day but batteries may have been a bit weak from a lot of start attempts). I put new wires on the coil packs when I first got the boat, but there was no immediate change in the motor's temperament.
Old primer bulb stayed rock hard after priming, new bulb is losing pressure with a quickness. I'm going to change the fuel hose from my separator to primer and from primer to fuel filter to eliminate any chance that they're shot. I'm replacing battery terminals to make sure that I'm getting all the juice I need tomorrow.
I'm just wondering if y'all can think of anything that would cause a no start issue when I appear to have fuel, spark and compression.
