Hey. Thank you for all the helpful comments and suggestions. I tried brute force with a slide hammer without success. I made a device to go over the prop shaft and using the nut on the prop shaft to exert considerable downward pressure tried to pull the prop shaft out, again without success. I am now thinking that something has come loose in the gearbox and is jammed in the prop shaft preventing it from being extracted. The shaft and attached bearing are quite wobbly in the housing but cannot be pulled out. The drive shaft is also seized which seems to confirm something jammed in place. My next plan is to carefully cut a hole in the housing to expose the area of the dog clutch and gears and see if anything can be freed up. I can weld the patch back without difficulty in that area. any comments on this plan of action?
Stuck prop shaft
look for a used or new lower unit
you can cut it up if you like to see what all happened in there, but the housing is trash in my opinion.
shafts ride in bearings, gears are meshed.
shafts either welded to bearings or gears welded to each other
, bearings are loose in housing.
machined fits are no longer good
This is exactly what I have. I have the service manual as well.. I have Nos 51-55 removed. except 48 ( the bearing) is still in the housing but the shaft rotates slightly so the bearing is not stuck to the shaft, but because of poor access I cannot get a puller on that bearing. The prop shaft rotates a small amount but cannot be pulled from the housing. I am inclined to believe that something in the gearbox is jamming and resisting the pull. It's now a contest of wills between me and an inanimate object and I must get to the bottom of the matter irrespective of expense or effort. Thanks for all the input and all further suggestions are welcomed.
42 was removed with the bearing carrier. 56 is still retained in the housing and may be the component preventing removal?
if I cut a hole to ascertain the problem has anyone any experience of welding these units? Is it made of aluminum or an alloy? Is TIG welding the way to go?
Originally posted by rodbolt17 View Postnot that I have ever disassembled that desighn case.
50 is what is jamming the works.
that thrust washer #50 and shim #49 are in between the bearing and gear when they are pressed together and then that is pressed into the carrier.
he got the carrier out but the thrust washer is stuck in the housing and it is keeping the gear from coming out.
the shaft is pinned to the clutch dog with #42, so it will not allow the shaft to slide out either
ÂÂÂÂÂ
