I have a 2006 Yamaha 25 MSH. I have been testing the ignition system with a digital multmeter and a DVA adapter. I am not sure if I have properly performed this test. I checked the coils for resistance. I disconnected the terminals to the stator, CDI, etc and got my voltage readings and everything seems to be within specs. My questions are:
1. What are the color coded wires to each component?
2. Are the terminals supposed to be disconnected or connected?
3. Does the ignition need to be tested while the motor is running?
The motor will die if the idle falls below 1100 RPM. The motor vibrated/shakes during idle/acceleration. It smokes more than it should. The compression test on both cylinders are 80 lbs. Carbs are new, fuel lines replaced. Head gasket replaced. Cylinder walls are not scuffed nor scored but do have some light brown/tan areas near top. Timing check was dead on specs. The new spark plugs- top #1 cylinder plug is black on the electrode and bottom #2 plug looks clean and no black. Fuel is fresh and the mix is 50:1 non ethanol, Wal Mart oil. New fuel tank and fuel hoses. I have the motor in a barrel of water and I have never put this motor on a boat to test under load. I did a decarb with some Sea Foam and I think I have burned all that out before I pulled the head. That's about it thanks. First time poster I think....but been reading and searching for a while on different issues.
Thank you for any replies.
