I have read many of the posts for this problem and mine seems different.
The oil will not transfer, either auto or with the manual switch.
I checked for voltage and ground at the engine connector in the pan near the shift/throttle linkage.
Key switch on:
Brown : no power
blue : no ground.
If I apply ground to blue wire and power to brown wire (at either side of the connector also) the pump works perfectly.
If so, is it a problem with the ECU. (Hope not) That is the only place that I can find the wires connecting to.
Key switch on:
Brown : no power
blue : no ground.
