Hey!
I've got a Yamaha 40 hp four stroke from 2002 with one previous owner. Since its been hanging around for 16 years, I've started to be a little be more aware of it although it has been working just great since I bought it.
I therefore thought it would be a good idea after all these years to verify that the warning/alarm system on it works as it should. I read at this forum that it could be easily verified by detaching the "dead man's switch" and then try to start the engine. I tried it multiple times, but the buzzer was not sounding at all.
I therefore opened up the "remote control 703" to verify that it had a buzzer, which it had. I connected it directly to the 12V battery to verify its condition and it sounded loud and worked fine. I then measured the two wires that connects with the buzzer from the harness (yellow and purple) with a multimeter, and when starting the engine without "dead man's grip" connected it went from 0V to 1V so something seems wierd here.
Next i tried to ground what I think is the water temp sensor on the engine to see if the water warning lamp would start to blink on the multifunction gauge which it didn't and of course the buzzer didn't sound either. (I attach a picture of what I think is the water temp sensor, it would be great if someone could verify that it is the right one that i'm grounding.)
To be sure that the multifunction gauge was working, I disconnected the data cables and grounded the green/white cable on the gauge and the water temp indicator started to flash so at least the gauge seems to be working. Same thing with the oil warning indicator (green/pink wire).
So, do anyone know what I can do next to find out why the buzzer is not alarming as it should?
It would also be great if someone could tell me where the oil sensor is located so I can try to ground that one and see what's happening. I attach some pictures of my gear if that can be helpful for you.
Thanks alot!!
Thanks alot!!
