Originally posted by Bojangles
View Post
New guy with a question
oh for sh*ts sake.Originally posted by Bojangles View PostI spoke with the mechanic this morning and he tells me his parts catalog does not show an item #7. I assume he is going direct to yamaha.
You (or he) can buy it right on this site,
from the Yamaha retailer who pays for us to have this forum,
Boscoe posted that link, here it is again:
https://www.boats.net/product/yamaha/64E-43811-01-00
You (or he) can type the part # into Google and get 4,820 hits
now, I do see an indication that it may have a newer part number: 64E-43811-02-00
here is a retailer showing the superceding part#
https://www.partspak.com/productcart...iABEgIUDvD_BwE
And you'll get the part CONSIDERABLY CHEAPER (even with shipping) than he will. Usually within a couple of days, at least to SW Florida..Originally posted by fairdeal View Post
oh for sh*ts sake.
https://www.partspak.com/productcart...iABEgIUDvD_BwEScott
Yep, the -01-00 has been replaced by the -02-00. Order the -01-00 or the -02-00 and the -02-00 will be supplied.Originally posted by fairdeal View Post
oh for sh*ts sake.
Either the dealer, the mechanic or the Yamaha man that was spoken to does not understand how to read a Yamaha outboard motor parts book. Training is needed. Yamaha USA has three US based warehouses. One in Georgia, one in Wisconsin and one in California. All three inventories have the 64E-43811-02-00 in stock.Originally posted by Bojangles View PostI spoke with the mechanic this morning and he tells me his parts catalog does not show an item #7. I assume he is going direct to yamaha.
Here is information from the Yamaha USA parts catalog at their website. www.yamahaoutboards.com
Ok, I am with you guys on this. Quick question, what does the 0407 number represent in the fourth drop down menu? Is that years 2004-2007?
He told me this morning that he entered my serial number in for my motor and it was not available. I am calling BS. I told him to cancel the sub assembly order.
I just called yamaha and based on my serial number the motor is a 2007 but at some point in 2007 they changed the tilt assembly. I had the earlier assembly which would fall under 0406 which does not allow for buying the screw separately. So, sub assembly it is. Thank you for all your help.
0407 stands for April of 2007. The beginning date for a given production lot. Yamaha had production lots that ran from April of a given year through March of the next year.
You can go to the Yamaha parts catalog and plug in your specific serial number in the applicable search box. It will take you directly to the parts book for your specific motor. By serial number. Once you get there go to the power tilt and trim section. See for yourself. Show your mechanic. Educate him.
In the first box type the engine prefix. 68M in your case I believe. Then the letter L for the shaft length. In the second box type the engine serial numbers.
Yes, you definitely need the complete sub-assembly. Buy two. Have one as a spare part for when you need it next time.Originally posted by Bojangles View PostI just called yamaha and based on my serial number the motor is a 2007 but at some point in 2007 they changed the tilt assembly. I had the earlier assembly which would fall under 0406 which does not allow for buying the screw separately. So, sub assembly it is. Thank you for all your help.
The only thing that changed is the parts catalog. Yamaha corrected a parts catalog mistake and started adding the end cap in the April 2007 and later parts book.Originally posted by Bojangles View PostI just called yamaha and based on my serial number the motor is a 2007 but at some point in 2007 they changed the tilt assembly. I had the earlier assembly which would fall under 0406 which does not allow for buying the screw separately. So, sub assembly it is. Thank you for all your help.
Yamaha does not go backwards and fix earlier mistakes or omissions.
I am confused. You said this:
Then you said this:
Are you saying the parts are the same or that I need a complete sub assembly?
