Originally posted by boscoe99
View Post
GPS Connection for 6yc
I’’m not sure if it works on a computer system or if you need a computer for the first setup and for advanced settings...
in any case I guess how to connect both devices if the GPS receiver can be connected only by a MD6 cable.
Also: even on the USB port I see written 5volts. But it’’s powered by a 12v system... I think 5v is the voltage for any device plugged in (i.e. battery charger...).
could it be the same for the GPS receiver?Last edited by PlutusMarine; 04-29-2018, 01:54 AM.
Hello folks! I finally decided to buy a GPS antenna for my Yamaha 6YC and I found the Garmin GPS 19x HVS (NMEA 0183).
Now, I was wondering how to connect both devices since I got two wires (blue - and white +) coming off the back of the 6YC.
Maybe with some pics it could be easier...
Actually, I don't understand exactly what garmin manual says at pag. 5... GPS19x_HVS_INST_ML_.pdf
Hope you guys can help me... Thanks!
The Garmin 19x is an excellent device - but the wiring is confusing. Lets work it out
To get GPS data to the Yamaha, we need to connect the transmit (Tx) of the Garmin to the 6YC (which is receive (Rx)
So the Garmin gray (Tx+) connects to the Yamaha white (Rx +)
the Garmin white/red (Tx-) connects to the Yamaha blue (Rx gnd - which is -)
that's it for the Yamaha connections.
However, you also have to provide power for the Garmin, so it can operate
So you need to connect the Garmin black to ground,
and the Garmin red to 12V+ power
(which you can switch off, so as not to run down the battery when you don't need it)
There are lots of way to provide that switched power for the Garmin -
if you have an available yellow wire connector
on your Yamaha keyswitch/remote control/gauge harness -
you could tap into that for the garmin
then it would work whenever your 6YC is on - but go off with it.
Â
