My 1998 115 hp engine is giving me an issue. My last outing i ran 35 miles and had zero issue. That was about 3 weeks ago. Today i put my boat in the water, engine started up no issues. Went on my way at slow rpm until out of the no wake zone area. Powered up the engine and ran fine. Was running it around 3500 rpms no issue but I did notice my tach spiking up a few times. The engine continued to run fine so i figure a bad connection or bad tach. Continued on my way and went a little faster to about 4000rpm. Tach spiked again off and on. Then all of a sudden the engine Boggs down. I ease back on throttle and wait a few mins at idle. Then try again. Ran fine up to 3500 rpms pushed it faster. Same thing.
So my question is, I know there is a rpm reducer but what could cause a false rpm reading and that reducer to kick in?
Or is this a completely different problem?
Also note that after i idle for a few mins I was able to run the engine at 3500 and at 27 mph to my fishing spot and back to the ramp. Only at higher rpms do i have this issue.
Thanks for the help in advance. And please let this not be a costly repair
