Originally posted by Seacraft12
View Post
1998 yamaha 115 hp false rpm causing rpm reducer to kick in?
Originally posted by ausnoelm View PostCan someone tell me how this is anything at all to do with "limp mode" you are still tunnel visioned about this.
perhaps the RPM spiking issue and the way the engine is behaving over 4000 rpms are two completely separate issues and I just assumed they were related.
What do you think is going on?
BTW, I talked to the local Yamaha parts dealer, they seem to think it may be thermostat, poppet valve related. he suggested to remove the thermostats, drop them into boiling water to see if the open/close freely.Last edited by CHEWBAKA1973; 11-20-2013, 05:19 PM.
Originally posted by rodbolt17 View Postquick test of the alarm.
pull the stop lanyard and crank it.
if it sounds your good if it does not fix that FIRST.
get over the limp mode sheet.
find a real tech.
do you understand what a thermo switch is?
Looks like i may have to. Any harm in replacing thermostats and trying to see if thats my problem. Yes I know what the thermo switch is. It's what triggers the engine to alarm and go into limp mode if it overheats.
Silly question. Where would this alarm/buzzer be located??Last edited by CHEWBAKA1973; 11-20-2013, 09:30 PM.
You seem to have a couple of things going on (or not going on) and this limp mode has got you fixated, first off you have to make sure your alarm works, then see if it IS over heating, of course it won't hurt to replace the thermostats, but it also won't help if they are OK. Trouble shoot before throwing parts at it.
Originally posted by ausnoelm View PostYou seem to have a couple of things going on (or not going on) and this limp mode has got you fixated, first off you have to make sure your alarm works, then see if it IS over heating, of course it won't hurt to replace the thermostats, but it also won't help if they are OK. Trouble shoot before throwing parts at it.
I am totally open to troubleshooting suggestions. Thx
Originally posted by 99yam40 View Postmake sure buzzer works
make sure temp switches work in spec
make sure stats work in spec
A pot of water and something to measure the water temp while heating it is simple.
need a meter to look at switch, but stats just need your eyes
Tried looking up the part number for my 1998 C115TLRW and wouldn't ya know it my year is the only year that does not have a buzzer listed. ????????Last edited by CHEWBAKA1973; 11-21-2013, 01:00 AM.
Originally posted by rodbolt17 View Postdepends on the control box.
703 side mount the buzzer is in the box.
704 binnacle mount the buzzer is on the key switch assy.
thermo SWITCH.
its ON or OFF.
OPEN or CLOSED.
there is NO limp mode.
your life will be a lot easier if you get a service manual for your motor so you can look things up if you want to work on it
Procedures and specs are all in there so you do not have to spend days trying to find some with the info you need that will post on your thread
