I have a 2006 250 hp 4 stroke. I keep the boat in the water. Went to use it today, turned on battery switch, lowered engine, started engine, then the engine started to raise itself. When i hit the switch on the control handle it would stop, when i let off it would continue to rise. Turned off the engine (had to otherwise it would be running out of the water) and the rise motor keeps running, only way to turn it off is to turn off the battery.
Any ideas?
Any ideas?
