I have a problem with a F225. It was running well then just lost power, stalled and would not run. When starting (have to use revs to get it to run) there's a lot of "carbon" (black smoke) and then it stalls. A mechanic has done compression test and al cylinders check out fine. Swapped over computer with good engine (twin set up) but no luck. Any ideas?
F225 gone mad!
two things.
1, have your mechanic swap EVERYTHING one part at a time.
2, find a real mechanic.
use the Yamaha dealer locator function, find a shop with a master tech.
in the time it took your mechanic to swap ECU's I could have diagnosed the problem.
in the time it took your mechanic to run a compression test I could have done a leakdown test,two cigarettes and a cup of coffee.
use that dealer locator.
ÂÂ
