Hi guys , I have a 2013 F225BETX (caribbean model) serial # 6AS-X-1003328B with 465 hrs on the motor. I do the 100 hr service myself as we live on a small island off the coast of Honduras and there are no "yamaha mechanics" certainly not certified. So the past 3 trips we have made to town which is 6 miles by boat I am running up on plane at 4200 rpm and its like someone just turned off the key !! dead, I put the motor in neutral turn the key to start it, Perfect, runs great, did our shopping, came out to the boat 4 hrs later, started home and into the journey about 1 mile , same thing, started it back up and came home without another incident , seems to do it 1 time per trip, maybe it will get worse / more often as time goes on. This motor is our car, we are boat access only and rely on this to survive, anyone have any clues to where or what it may be please ??? I dont think its water in the fuel, because it doesn't run rough, it like turning off the key every time it happens.....
Please help if you can
Thank you
Ken Hammer
Thank you
Ken Hammer
I hope it is, though. Yeah, electrical connections are very important - especially for newer engines. It's possible the lug was a little loose, too. Take a few minutes, though, and do the rest of the connections - it's time well spent, at the dock, rather than trying to do it in the water somewhere. Cover the connections with a spray-on terminal protector, or at least a coating of grease. If you keep up with keeping them clean and protected, you "shouldn't" have this issue again.
