I am swapping the entire unit out on an engine, was wondering if this can be accomplished without taking the engine off of the boat
2008 Yamaha F250 TXR Trim and Tilt Assy
as long as the boat is on land - no reason to remove the engine from the boat!
I would start by disconnecting the t/t motor wires from the t/t relay, and pulling them out of the bottom cowl
then apply battery power directly to the motor leads to tilt the engine all the way up (blue positive, green negative)
let it back down safely on the "tilt support lever" and have at the unit removal
Originally posted by 99yam40 View PostI thought at least one clamp bracket needed to be loosened up to give it some room.
plus need to support the motor if bracket it taken loose to remover the T&T unit.
tight fit.
but then I have not done it before on a F250
I have removed many F250 trim and tilt units but only on motors that were on an engine stand. Never had to do anything but remove the feed wires from the T/T relay and snake them out of the lower cowling, uncouple the trim sender wires, unbolt the bonding wire, remove the pin holding the tilt piston to the bracket and then unbolt the body of the trim/tilt unit from the brackets. Power the tilt piston down and then slide the unit out from between the brackets.
Seems that according to rodnut the procedure is the same even when the motor is bolted to the boat. I would certainly start by trying that.Last edited by boscoe99; 01-20-2018, 11:17 AM.
tight fit.
I just posted and it got disapproved. Sent off to a moderator. Don't know why. Strange, very strange.
What I said was that I have removed the T/T unit without spreading the clamp brackets even though the SM says to do so. But I have done it with the motor on an engine stand, not on a boat. I tend to agree with rodnut. Try it and see what happens. No harm no foul.
Ok it came off without taking the motor off the engine, too easy, compared to what i envisioned, but it is not back on yet either. Just make sure the main tilt cylinder is all the way down, and the unit comes right up and out.
looking for opinions to treat the mounting bolts, blue locktight, perfect seal or never seeze?
Yamaha calls for Loctite 242.
Some use Loctite 242. Some use grease. Some use Three Bond. Some use never seeze. Some use pipe thread compound. Some don't use anything at all.
http://www.loctiteproducts.com/p/t_l...r-Blue-242.htm
Originally posted by fairdeal View PostI suspect you won't go wrong with any of those, (although copper based anti-seize is always good for an internet argument)
this is what I've used for those t/t unit mounting bolts, and happy with the results.
ÂÂÂ
