i have what i believe is a 1980 60hp mariner.i cant find the serial # to make sure its a 1980. the only # i have on a metal tag is 675L31500 made in japan. please someone help with this problem.
frustrated
That is a yamaha built 60 hp mariner. and that is the number you need, any older mercury dealer should be able to take that number and get you the parts you need. and the reason I say older dealer, I used to be a mercury dealer and we had a laminated cheat sheet that had the make and model and serial numbers on it with the year model that corosponded with the number. and with that informatin I could look up the parts.. Hope this helps.
Question, I had (first new boat), a Glastron 15' speed boat with a 1980 75HP Mariner engine (white). Was that a Yamaha engine too???Originally posted by Sequoiha View PostThat is a yamaha built 60 hp mariner. and that is the number you need, any older mercury dealer should be able to take that number and get you the parts you need. and the reason I say older dealer, I used to be a mercury dealer and we had a laminated cheat sheet that had the make and model and serial numbers on it with the year model that corosponded with the number. and with that informatin I could look up the parts.. Hope this helps.Scott
