Two of the carbs keep flooding out on my motor. From what I can tell there must be some type of a check valve in at least one of the passage ways in the carb body itself that is sticking. Is there anyway to service/replace these without replacing the entire carb body or does anybody have any ideas to keep them from sticking? The same two carbs flood no matter where they are placed in the stack. They have been cleaned multiple times and put back on. The motor will run fine until one of them sticks and then it immediately floods and won't run. If you are looking at the carb stack you can see gas running down the sides when it happens too.
Thanks in advance
Thanks in advance
