Power head 1991 30ELRP
lower unit 1997 (model unknown)
I just got this motor used and replaced the water pump because the previous one was not working properly (no water coming out exhaust). After hooking up the muffs still no water coming out exhaust at idle or drive. Checked the exhaust nipple and the hose it is attached to on the powerhead - no blockage and I was able to blow air from the exhaust tube to the intake (small amount of water came out intake). If there is no blockage and assuming the water tube is seated properly and pump installed correctly is there anything else that might be the problem?
Thanks!
Rob
Thanks!
Rob
