Just had the carbs re-built and rest of fuel system replaced (fuel pumps, filter & housing, and a new fuel/water sep)
Motor runs great after starting, and will restart right at the crank after the first "cold" start, even if it has set 30-60 minutes.
But when I get to the boat "cold", I pump the primer bulb hard, then turn the key and press in the electric choke. Motor turns right over, but it seems like it takes me three or four cranking tries of 10 secs each, then finally a sputter or two, then she fires up and runs great the rest of the day.....
Really seems like there's no fuel......until there is fuel!
Suggestions???
Suggestions???
