Motor is a 2000 OX66. Model SX150TXRY. Motor has about 12 hours on it this season since fuel filters, low pressure pumps were changed. Problem is when throttling up to get on plane, the motor cuts out and drops back to idle. one time it stalled. Starts right back up and is fine afterwards. Its only happened a few times but id like to fix it before it gets worse. No alarms, or flashing indicators on the guages. Ive been on the boat once when it happend but wasnt driving. Boat fired back up no problem and we continued to cruise. No RPM loss at cruise. Boat ran great.
Outside of the obvious like fuel filters, fuel quality etc. I was gonna run it with a fuel pressure guage and try to get it to happen to see if its a fuel pressure problem. Is there anything else like a TPS sesnor that could be the culprit? From my understanding these engines will only set a code when the fault is happening and wont store codes. Just looking for some ideas from the more experienced guys as to what to look for.
Thanks Mike
Thanks Mike
