I resently had an issue with my 30 amp fuse blowing. Come to find out the regulator / rectifer had a short and burnt to a crisp! Here is my question, on the F80 Electrical 1 diagram, it shows two different part numbers...67F-81960-10 and 67F-81960-12. How do I know which one to order? Thanks in advance!!
Yamaha F80 Regulator / Rectifier
I'm sure the Boat.net folks will chime in to help you out....Originally posted by Kentucky Lake View PostI resently had an issue with my 30 amp fuse blowing. Come to find out the regulator / rectifer had a short and burnt to a crisp! Here is my question, on the F80 Electrical 1 diagram, it shows two different part numbers...67F-81960-10 and 67F-81960-12. How do I know which one to order? Thanks in advance!!
BTW - My regulator burnt up a while back too. I was told the most probable reason mine went because my battery terminal came loose because I was using wing nuts instead of wrench tightened bolts! Just something to watch out for.
Charging Problem on F80
I'm researching possible causes for my battery not charging. I never read more than 12.3 volts regardless of RPM. Is there a way to use a voltmeter to check the rectifier/regulator to see if its the likely culprit. Seems like several F80 thru F115 Yamaha's have had regulator problems be it from the component or from bad connections/bad batteries. Would like to troubleshoot it before I drop $200 on a part swap. Any help would be appreciated.
Yam F80 rectifier/regulators have been known to be problematic. There is a reason that they are now on the 13th design change (twelve dash number changes to the basic part number).Originally posted by cuinorange View PostI'm researching possible causes for my battery not charging. I never read more than 12.3 volts regardless of RPM. Is there a way to use a voltmeter to check the rectifier/regulator to see if its the likely culprit. Seems like several F80 thru F115 Yamaha's have had regulator problems be it from the component or from bad connections/bad batteries. Would like to troubleshoot it before I drop $200 on a part swap. Any help would be appreciated.
Check the input to the rectifier/regulator from the lighting coil to ensure that it meets specifications. If so, and if the output is only 12.3 volts the rectifier/regulator is defective. It is nominally 13 volts. Typically however you should be seeing in the neighborhood of 14 to 14.5 volts.
