Hello,
I have a 1997 Yamaha V115 with an intermittent/no spark problem. I can usually get it fired up initially, but after a while of running, it will die at idle and be very hard to start, sometimes not starting at all.
I checked spark on all 4 plugs and they are intermittent for a couple seconds, then nothing. Let it sit for a while, same thing, little bit of spark, then nothing.
I checked the kill switch wiring, ignition sw wiring by disconnecting the white wire, no difference. Disconnected the whilte wire at the bottom of the CDI, still no spark.
Bad CDI? Any way to test it? Dont want to throw 400 bucks down the drain.
Thanks for your help...I need to go bass fishing!!!!
