when the key is in the on position the alarm sounds (barely) and the multimeter reads 2 volts comming to it any ideas???
1991 200 yamaha 2 volts at buzzer with key on
check your sensor connections if they are ok check the buzzer they are prone to corrosion its a simple mechanism made up of a thin brass plate that vibrates when power is applied to it open up your control box and give it a cleanLast edited by jazzman44; 04-06-2013, 07:57 PM.
its a new buzzer. and it does not go off when engine is started but it does get louder when oil is low . COULD IT BE A LOW VOLTAGE SIGNAL?
Yea but 2 volts at it . shouldent there be 0v at it unless something is wrong. Then it should get 12v
should have 12V at the yellow buzzer wire at key on.
the temp switchs and oil alarm module control the ground path.
no ground,no alarm.
ÂÂÂÂÂÂÂ
