when the key is in the on position the alarm sounds (barely) and the multimeter reads 2 volts comming to it any ideas???
1991 200 yamaha 2 volts at buzzer with key on
check your sensor connections if they are ok check the buzzer they are prone to corrosion its a simple mechanism made up of a thin brass plate that vibrates when power is applied to it open up your control box and give it a cleanLast edited by jazzman44; 04-06-2013, 07:57 PM.
ÂÂÂÂ
