going to change water pump on my 2009 115 4 stroke f115tlr and was wondering if the shift is splined or do i have to unhook linkage ?
water pump
Water pump
The parts fisch:
2006 and Later 4-stroke F115TLR Yamaha Outboard LOWER CASING DRIVE 1 Diagram and Parts
shows it to be splined(part #17).
Don't forget the bolt (#8) in the housing under the steering trim tab:
http://www.boats.net/parts/search/Ya...202/parts.htmlLast edited by TownsendsFJR1300; 03-22-2013, 08:49 PM.Scott
As I re-call on my F150, just gently work your way around them slowly prying them upward and off. Slow and easy so they don't bind.Originally posted by RonH View Postis there a trick to getting off the spacer #20 and looks like collar drive shaft #23?
wanted to ask before i got to ruff with it
Some liquid lubricant would help. There's no secret retaining clips, etc...
Good luck..Scott
